You'r alright with that cut, but if you screw it up again, that head is paper weight.russ88 wrote:My CA18DE blew a head gasket. The cylinder head measured low in the center and high on the ends. I had to fly cut .018 off the surface to get it straight again. How much is too much to remove? Anybody know? We are on a strict budget and are just trying to get running again. We will be doing an engine swap later on down the road when money allows.
