Ca18de - Cylinder 3 - no spark!
Hieko
Car: CA18det - 92' 240sx hatch
I am currently working on my relatives Nissan pulsar nx 88' w/CA18de. I am familiar with the CA engines, as i have a DET model myself. My current problem is getting spark on cylinder 3, its non existent. i have been swapping parts from my CA to hers to help me isolate the problem, here is what i have determined are not the problem.
*coil packs
*coil pack - wiring harness
*spark plugs
I am about to try swapping the power transistor to see if it persist, some questions i have are:
*what else should i try swapping?
*is it possible for the power transistor possible supply functional spark to all but one cylinder?
The vehicle currently runs and idles on 3 cylinders but i had to advance the timing to keep it from dying until i was able to diagnosed that a cylinder did not receive spark. i am going to swap all possible parts of the ignition system until i isolated the issue.
BTW ~ I've been reading forums from Nico about CA18's for two years now. I figure it was time to make an account and become apart of the community :)
Hieko
Update, my cylinders are actually getting spark. with the ecu reading 55 "a okay" my next step will be taking a look at the mechanical timing, she has 190000 miles, may have skipped :(
