timmyc4 »
https://forums.nicoclub.com/timmyc4-u78776.html
Wed Nov 07, 2007 6:15 am
Updated question:11/12/07*
I've been reading and researching this for months, however some links are broken, or email's don't work anymore. So....Here's what I have.1. 88 NX SE with CA18DE (blown hg) 5spd - the subject car 2. 87 NX Se with CA16DE also blown HG - Donor car if needed.3. U11 Bluebird CA18DET w/58k complete with transmission, ac/ps, wire harness, ECU, AFM. Now, from everything I've read @forum.nissanexa.com and @forums.nicoclub.com the best solution would be to do the swap to the 88, using the 87 CA16DE harness, and the U11 ECU. Here is my question, doing that:1: the CA16DE harness connectors do fit to the U11 ECU, but there is a middle connector that has no where to go, just wonder what that might be for.2. The U11 seems to have old style distributor and what not and I just swap the correct ones off the Junk CA16DE motor and install them on the CA18DET right? Going this route, it seems that I can use the U11 ECU with the CA16DE wire harness, I just need to swap over all the DE16DE components on the harness/motor to the CA18DET. No one seems to have done what I'm doing exactly, but it seems to me to make sense.Any advice would be appreciated!
*So many good replys, thanks guys, NOW here's what I need if someone could help me. I have not seen anything about this even with Tim and Craig's good pics and post.How do you exactly put in that dropping resistor(s) for the injectors in the CA18DET into the CA18DE harness, and more importantly could someone post a pic about that, and how you did it ?Again, I do have the U11 Harness, can I graft it out of there?
Thanks!
Modified by timmyc4 at 9:00 AM 11/12/2007
Modified by timmyc4 at 9:03 AM 11/12/2007
Modified by timmyc4 at 9:05 AM 11/12/2007
