PulsarDet »
https://forums.nicoclub.com/pulsardet-u30679.html
Thu Oct 12, 2006 4:23 pm
I do run a SR20DET Ecu with the ca18det wiring in my pulsar. So far it's pretty much easier, to update my map's and tuning the ecu. The only thing is a more expensive way than the standar ca18det and wiring. You will need a few thing. The SR20DET ecu, a dauther board but with the dauther board you will be able to use the consult port of the ecu on a laptop or computer so more easy to see the code and also you can use calumsult software to see all the reader of the sensor, like water temps, oil pressure, boost, timing ect... quite impressive.
Well worth the price and effort for me.
