sdtouge wrote:Does weight distribution even matter that much for drifting. thanks in advance
Yes, it does. Weight distribution affects oversteer/understeer, among other dynamics of the car's handling. Weight can be compensated for with suspension work (it is in every car) but you're fighting the inherent physics of the car just to get it to neutral BEFORE you adjust it to drive in the style you desire.
Overall a lighter car is also easier to drift without excessive use of power-over technique. Easier to break loose, easier to rein in. This is normal Newtonian stuff; "body in motion tends to stay in motion, body at rest tends to stay at rest".
Yots, I shouldn't be filling the CA forum with this stuff.
Quote »plus for you ca/sr guys is it hard to get things like oil filters and belts etc.? [/quote]
Picked mine up at the dealership last Friday.
