float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed May 27, 2009 7:17 pm
Yea, that doesn't really work. You have to follow the outline in the FSM. If you don't, the ECU doesn't default to the stock timing values and you're not really setting the timing to what you think you are.
Basically, unless you follow the procedure in the FSM, the ECU modulates the timing at idle to maintain a good even idle. So if the ECU is trying to run the motor at 13 deg, and you set it to 15, you just advanced the entire timing map 2 deg. Does that make sense? And it can go both ways, I just gave an example.
