Thanks for the replies , It's not that I dont have the money to get the ca flange welded on to the z32 box (I would probaly do that myself) but would be nice if there was an easier route but I quess It's either change the box or swap the engine then.
I still think it's a bit weird the output shaft snapped , when you dump the clutch (correct me if I'm wrong) the power is transmitted from the clutch to the gearbox , and from the gearbox (outputshaft) to the driveshaft then to the diff and the wheels , I thought the weakest link in that chain would be the tiers and that they would just lose traction , but obviously the weakest link must have been the outputshaft , but the outputshaft on the Z32 is the same diameter right ? so will it still be less likley to break ?
And yes I will practice slipping the clutch instead
