Tru180Kid »
https://forums.nicoclub.com/tru180kid-u135451.html
Fri Jul 17, 2009 1:38 am
**cliffnotes, under boost the car isnt making the kind of power it should, maybe runnning in limp mode or the knock sensor**
Well i finally got the car up and running, i thank everyone for their info and help, now despite the IACV ebing broken, she cranks over and willl run good, if not decent. The most recent issues ive come across is Once i hit boost and get the rpms up to 4k, the car feels as if its falling flat on its face, or not making enough power as it should.
I noticed this because i gave a 1st and 2nd gear pull against one of my freinds car, and i walked him but a few days later we go again and i could barely keep up
but back to the issue, it was mentioned to me by fabio240 that the knock sensor, could be causing teh car to run in limp mode when it gets under boost. I checked the ecu for codes and it thre 34 - 3greens 4 reds, which im told is the knock sensor. On top of that, the car is running extremely rich.
Secondly, after driving the car for 20-30minutes straight, my temp gauge starts to rise, im running coolant and water. It rises mainly when im in boost. On average the needle sits betweent eh 2nd and 3rd bar, then it will rise up to the 4th and 5th bars. I was told ther could be air in the system, and that fact that my radiator has 200k+ miles on it.
Granted ive only had the car running for a couple of weeks now, but i can tell the difference in the power from when it was running right to how its running now. I was also told that stock psi on the ca18 is 9? thats what im running now. any info to help me with the problem would be nice
