Yes I know it seems really weird as I thought it was a blockage or something but I do not have a cat in my car but a full 80mm exhaust dp/tp/cb. A friend of mine had a racing cat fall apart on him and plug up a pre-muffler on his catback and his car would feel very laboured until we found out what happened and gutted the cat and removed all the blockage. I unplugged my catch can lines from the valve cover/intake pipe as I have seen similar idle and throttle issues when it fills up and prevents air flow but it is not the case either.r34 gtr wrote:Thats very strange that it would just happen all of a sudden like that. Does the exhaust have a cat on it? It could be blocked if there is, which has been known to cause similar problems. Another thing it could be is the coolant temp sensor. I would check both and see if it doesn't help.
I wrote the codes down as there was one and I will post it later..... The car does not puff black out the back though but I will change the coolant temp sensor from my other CA18. I still think it is not entirely a problem with the coolant temp sensor as it seems to lack ignition rather than floods out, it fires up quite easily considering how the plugs look.r34 gtr wrote:Hm, how about the Coolant temp sensor? Those cause very rich conditions when they go out. I assume you have checked the ECU for codes?
Yes I swapped ignitors already as well as coilpacks and harness. The ECU plugs are the first thing I made sure was tight, this is why I am so at a loss about this. It seems like a ground or sensor kicked the bucket all of a sudden.r34 gtr wrote:Swap out the igniter if you think it is ignition based, and see if that helps. It could be breaking up as soon as there is a load on it. Also check your grounds and make sure all your harness plugs are on tight.
wonder why.......r34 gtr wrote:Good luck man, I'll let you know if I think of anything else. Post up the code, I know them all.
I do not as I can usually fix most issues I have but now I am getting a bit frustrated with this one .... I think you should come over and give me a hand one night with this :PBuddyworm wrote:Gasp! Scott's having CA trouble! My world view is shattered
Didn't know you frequented this place
Yeah I will need to check the o2 sensors as that is my next mission.ca18detgabby wrote:since you seem to have lots of extra did you try a second ECU? you loosing something somewhere along the lines.
did you check the new plugs u put in as to coloring? almost sounds like you have an issue with your Thorttle cable or something.
also, are your O2 sensors good?
"I redid all the ground on the harness by taking them off the body/engine and refastening them."DALAZ_68 wrote:i say check grounds... and make sure grounds arent blocked by rust or something...its the cheapest thing to do first
sorry to thread jack for a second...
but what about cold start problems ?
i have to crank my motor twice to three times for it to start...my timing is dead on and belt is now nice and new...i checked my grounds and multi metered everything???
could it just be starter?
I used throttle body cleaner on it and it seats properly and the throttle cable is proper tight but not holding it open at all.r34 gtr wrote:Could the throttle body be sticking open a little bit? Or maybe one of the dumb idle valves is stuck open. Then it would be getting too much air when you go to crank it, and it would need a little time to flood until it was rich enough to fire up.
my CA did this when I first did my swap........r34 gtr wrote:Could the throttle body be sticking open a little bit? Or maybe one of the dumb idle valves is stuck open. Then it would be getting too much air when you go to crank it, and it would need a little time to flood until it was rich enough to fire up.
I was asking if the new plugs you put in were still fouling after you swapped the new ones. if the new ones are pretty clean, then your not over fueling....typhoonslippery wrote:As for the plugs what do you mean? They are totally black and smell of fuel so the code for ignition 21 is correct as it is not getting enough spark but what it is due to is unknown as of now obviously.
MAF is all good as I repalced it with a BRAND new oneMeanGreenS13 wrote:check your MAF
he said he has 2 running motors. he is also in canadar34 gtr wrote:A brand new one from what? As far as I know, you just can't go out and but a DET maf...
From Japan-land, I try to have alot of extra parts for situaitons like this but most things have been unsucessful thus farca18detgabby wrote:
Ive been piling up parts and keeping things as back ups just to cover my rear end.typhoonslippery wrote:
I tried a good working ECU and an unknown ECU(Mine's) and both made the car respond similar with no change unfortunatelyca18detgabby wrote:
Replaced it with a good working one as one of my extras turned out to be junk. Still the same issue and I haven't been able to spend too much time with it lately so I will revisit this on the weekend.Buddyworm wrote:Have you tried a different CAS yet dude? Maybe it's wonky and just isn't throwing the code for whatever reason. It sounds like the only thing you haven't checked yet.
