CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Tue Jul 15, 2003 1:51 am
you guys want to start a group buy on the Power Enterprise F1 Black Bearings???
Power Enterprise Link (in english - translated)
If you mention the highest peak of motor sport, after all it probably is the F1. The ƒgƒbƒvƒhƒ‰ƒCƒo?[ of the world competes technique, there is also a reason that is funny as a race/lace, but also always saying the leading edge mechanism, has raised the position and charm of the F1.
Because the ultra-advanced technology which is thrown to the F1, whatever saying, polishes under that severe condition, if it is fed back generally, you promise high reliability and high performance. Being " F1 technology " how word it is expressed well, but also this F1 black metal, just is F1 technology itself. Those which stretch copper * lead alloy being attached on the steel base where strength is difficult to cause plastic deformation high are used to the high rotary engine and the like. It is the kelmet metal where this is used usually.
The F1 black metal, furthermore through nickel bond layer, has stretched the overlay of the thickness 15 micron which is a kind of coating. The high performance where this overlay is preeminent the F1 black metal is administered. Surface condition of overlay, having entered state of the kind of ƒMƒUƒMƒU the pyramid to be piled up, when you set the crank, contacts in the point vis-a-vis the general metal contacting in the surface. Because of that the friction decreases substantially. Furthermore when heat generation is little in comparison with the metal of interview touching, uses the usual kelmet metal compared to you say it is possible as many as 20 degrees in crank temperature to hold down low. Furthermore it meaning that the oil enters between the ƒMƒUƒMƒU of pyramid condition, also lubricating efficiency improves.
In other words the F1 black metal makes potential rise possible with the friction decrease of the crank, actualizes the improvement of durability by holding down crank temperature. Actually, as for the effect at the point where many tuners have already verified. The ƒ[ƒ?ƒˆƒ“ƒ^ƒCƒ€ was reduced nearly 1 second with a pop, there are no with several degrees until now and when they used the F1 metal in the RB26 of the ƒnƒCƒ`ƒ…?[ƒ“ where the metal has burned, the case that is not unusual, it stopped burning, it seems. It is durability of the F1 black metal itself which, becomes matter of concern, but the live may think 2 times that the normal metal.
*In world of F1, that M. ShoeMach Ferrari - being used, the F1 black metal which obtains numerous victory. It improves potential and durability together, it is the attention part whose cost performance is high. [/quote] *(are they saying that Ferrari F1 team uses Power Enterprise bearings??? if so i think they should work)
CON ROD - CA18DE (T) 20,000 yenCrank/Mains - CA18DE (T) 29,000 yen
the come in different grades and thickness just like the OE here is the link for info on that.
Grade and Thickness for F1 Black Bearings
