ca18 question
ilovedrifting
Car: skateboarding and drifting
i have recently been given the opportunity to acquire a 240 with a ca18 with a cracked piston head. is this pretty easily fixable or is the engine just not quite the same afterwards? any help is appreciated
thanks
float_6969
My concern would be what happened that cracked the piston head. I would assume it was just overheated.
Best case scenario-slap on another head and you're good to go.
Worse case scenario-some sort of internal damage has befallen the bottom end as well and the motor will need a full tearn down and rebuild.
Depending on the price it could still be worth it.
davidricardo86
Car: 1992 Nissan 240SX SE
Piston head? I didnt know the piston had a head. But if its the piston then its a lot of work and money. If its the head, then its a lot of work and money. Overall very expensive and probably not worth it. I could be wrong, let us know whats up.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
piston head = cylinder head. you can probably scrounge up a used head somewhere for not too much.
