datsunboy »
https://forums.nicoclub.com/datsunboy-u15035.html
Mon Mar 19, 2007 3:41 pm
Hey guys, I remember reading somewhere, that if you want to remove the Knock sensor, that you have to install a resistor in its place, to avoid the ECU from recieving error codes, or entering knock mode?
I've tried searching, but theres over 8 pages of results, just thought I'd see if anyone else remembered what Im talking about?
I need to do this in order to make the ECU run correctly on a different engine.We are installing the CA18 ECU and harness e.t.c. onto a Z18ET ( oldskool single cam turbo nissan engine ).and we assumed that the CA knock sensor would be "tuned/calibrated" to the characteristics of the CA.....so may not read correctly on a different engine.So think it would be more safe to just get rid of it.
