I second this... unless your trying for the whole jdm rhd thing.... but still kinda silly.ca18detgabby wrote:why on earth are you getting a shell from japan? there are a billion forsale locally...... for 1/100th the cost
Ive seen S14 shells go as cheap as 100 bucks..... clean ones going for under 2k.....foolycooly wrote:Lol, 3500 for the shell is a lot cheaper than anything else I could find
Thanksjt15833 wrote:this will get your wiring done...http://www.skylineking.com/fsm...4.pdf
im using nismo motor mounts, part # can be found in the faqstock KA transmission mount
using a 200sx bellhousing w/ a ka24de transmission, only because my ca18 was automatic.
using the stock s14 components from the driveshaft back, including the driveshaft (i had to remove collar at back of transmission to prevent driveshaft from rubbing
using koyo radiator, but the stock s14 should work.
goodluck!
