CA18 install??
gearheadz23
Yes im a noobie. but theres all these stickys and none of them tell you what all to do to put a CA into a early 240 hatch, a little help
Dirty Dee
Car: 1989 240sx
I am pretty sure that is is almost the same as installing the SR
S13FX
Car: '69 l20b Dimeski :)
Ok It is the same as SR swap even the wiring is really simple here are some links hope this helps. It took a couple of drinks and 10 minutes of searching lol.
http://www.frsport.com/sr20det....html
http://www.srswap.com/faq/index.asp
float_6969
Same as an SR swap. The links in the previous post are appropriate.
tyrannix
Car: go big or go home
float_6969 wrote:Same as an SR swap. The links in the previous post are appropriate.
actually, easier (cheaper?) than an SR swap, as you can reuse your old radiator
CJ
float_6969
You can w/an SR swap, but you've got to jury rig the rad hose.
