awretham wrote:I take it the engine's sitting as low as possible
The engine cant go any lower unless i can have the sump modified as it sticks out under the car already by 50mm!
awretham wrote:Does the plenum hit the bonnet?
Yea!
mr.mk1 wrote:The front Cam pulley cover and backing plate sits at the same, if not fractionally higher height
Thats next on the list
ca18detgabby wrote:Are you running a standalone or stock ECU?
Currently Stock, Wantstand alone though!
niscort wrote:i think this link still works
SWEEEEEET!
