For the individual that must have oil squirters, you can actually add oil squirters to whatever block you want to. The CA blocks have enough casting to make this happen (experience taught me this
). If you can tune, your pistons can survive without them. And if you can really tune, you can take a CA18DE, convert it to a turbo application and get reliable/modest power out it. Just like float, you'll have high compression to give you good low rpm torque and the added power from the turbocharger will compliment that in the range of 2800rpm and beyond. Again, if you can't tune, don't even bother. Just get you a stock CA18DET and go from there.
