pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Mon Oct 27, 2003 5:04 pm
Hi,
As boost boy said the car must be an 87 because the ca16de only came in that year, the engine is gutless, 110hp, the harness should be ok with out any mods if I remember correctly, I know the ca18de injector plugs have to be replaced to a ca16de in order to work on the ca18det , also the ca16de 02 sensor has 3 wires, while the ca18de has only one wire, and assuming that you had the ca18det in your car running, then you must have the 3 wire 02 sensor in there as well, so you don't need to replace any plugs.other than that, every thing should be the same, beside rerouting couple wires around.
But it isn't worth the headache and the effort, the ca16de is only good for parts since it has no power man.
Good luck,
PULSAR GTR
