float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Jan 28, 2014 11:37 pm
I don't know anything about RB pistons, but I can tell you the main issues to be concerned with are diameter (which it seems like you already know is the same), placement of the valve reliefs, clearance for the oil squirters and compression height. Compression height is the distance from the center of the wrist pin to the top of the piston (if it's a flat top, which it should be). If you can find all of that info, you should be able to compare those numbers and see if it will work.
