CA16DE cams in a CA18DET?
Brocephus
Car: 1984 Pontiac Fiero
Someone on a local forum recently told me that if I were to remove the cams from my CA16DE, I could swap them into my CA18DET and make more power as the CA16DE cams have greater duration and lift on the intake.
Is this true or can anyone dispell this as a myth?
themadscientist
rumor.
Option shot it down years ago and my FSM says the same.
two exhuast cams works though.
Brocephus
Two CA18 exhaust cams? If I remember right, the CA16 exhaust may have the same profile as the CA18 exhaust so I may have just answered my own question....
Found the cam profiles for each.
CA16DEIn lift - 8.5mmEx lift - 8.5mmIn duration - 248Ex duration - 248In opens - 15 BTDCIn closes - 53 ABDCEx opens - 59 BBDCEx closes - 9 ATDC
CA18DETIn lift - 7.8mmEx lift - 8.5mmIn duration - 240Ex duration - 248In opens - 0 BTDCIn closes - 60 ABDCEx opens - 59 BBDCEx closes - 9 ATDC
themadscientist
I picked that trick up from a 4AG guy. Worked well on my RB20DET, power up top got a kick in the pants.
Brocephus
Good deal, I'll have to let ya know how it goes in a CA18, hehe.
turbos12
Car: 1985 nissan 200sx
i just did the exhaust cam on the intake side mod..gains are hardly noticeable
Brocephus
Would you say it's worth the trouble if you already have the engine out of the car?
turbos12
well it isnt too hard to do..and u have the motpr pit of the car already..so just do it lol
D_Stirls
Car: Nissan 180sx 1990 Ca18det
Did you use a DE or DET exhaust cam? You should be using the DE cam as the DET will need Adjustable gears to get the most out of it.
Have a read of this;http://www.nissansilvia.com/fo...17&hl=
Brocephus
Don't have time to read it yet, but that link's on my list of top ten things to do today D_Stirls.
ReeceZ
Car: Nissan 200SX
Hi guys, tried the CA18DE intake cam on the CA18DET (intake side). huge difference after 4000rpm
D_Stirls
i don't know why it would make a difference as the intake cams are identical between the DE and DET, it's the exhaust cams that have the different lift and duration; Unless it was EURO specs as the EURO DE is 248 x 8.5. there is more power to be made by timing than lift and duration unless you have a large turbo which is where you need the extra lift and duration.
JPN spec CA18DE S13...In lift - 7.8mmEx lift - 8.5mmIn duration - 240Ex duration - 248In opens - 0 BTDCIn closes - 60 ABDCIn center lobe angle - 120degEx opens - 59 BBDCEx closes - 9 ATDCEx center lobe angle - 115deg
JPN spec CA18DET S13...In lift - 7.8mmEx lift - 8.5mmIn duration - 240Ex duration - 248In opens - 0 BTDCIn closes - 60 ABDCIn center lobe angle - 120degEx opens - 64 BBDCEx closes - 4 ATDCEx center lobe angle - 120deg
EURO spec CA18DE...In lift - 8.5mmEx lift - 8.5mmIn duration - 248Ex duration - 248In opens - 16 BTDCIn closes - 52 ABDCIn center lobe angle - 108degEx opens - 50 BBDCEx closes - 18 ATDCEx center lobe angle - 104deg
slideordie85
Car: 240sx
I am picking up a set of both CA16 and CA18DE cams this weekend.
Hopefully I will either be able to debunk or prove it this weekend.
I have read tons of threads and some say yes and most say no.
