So what I gatherd from your post, Dee, is that ANYTHIING SR related is not for heavy-duty use... sounds about right
although I do take offense to the E16 part. That's my baby, lol.
To my memory the common problem with the RS5F31A is 5th gear pop-out, which is caused by the engagement on the shift collar being too short making the engagement teeth wear out abnormally fast. Nissan made a revised fifth gear kit that changes the engagement from 1mm to 2mm and a pop-out fix kit is available that replaces the collar, fifth gear on the input shaft, and the seals and gasket that you'd be stupid not to replace while you're in there. Granted, I'm not saying it isn't a weaker transmission, because it definitely is, just to my knowledge the 5th gear pop-out is the main reason for getting rid of them.
But my point is that I'm waiting to find a good '88 Pulsar to use for my monster build, and when I do the transmission is staying in that car. Right now I'm just planning to get my current N13 back on the road, but with a few added goodies. So in the mean time since the RS5F31A is an inferior transmission and essentially worthless to us, and since I have a spare in my storage unit that already has 5th gear out so I REALLY don't care about it, why not see what it takes to make one of these pop
. Plus I don't really drive the car a lot, and when I do I have a hard time really putting it through any abuse that most others would (Idk, I just have a fear of breaking stuff. I'll put on the throttle without a worry, but I can't bring myself to drop the clutch from 43,000rpm and power shift every gear everywhere I go. Even though it is just a toy.)
So anyways, just to clarify, I'm unsure exactly what you answered, Dee. Did you say "no" I shouldn't bother, or "no" a CA18 pressure plate won't bolt up to a CA16 flywheel?
