matty »
https://forums.nicoclub.com/matty-u38151.html
Wed Dec 06, 2006 12:38 pm
so the other day the car started fine and then died immediately after.
since then it has not fired once.
turns fine, but motor wont fire.
heres what we know:
battery is fine, starter is fine, fuel pump is fine, fuel filtr is fine, lots of spark, low compression is out of the question, and timing belt is fine.
the weather went from warm to extremely cold while this happened, liek first snowfall of the year cold.
someone sugested the iacv.
woudl this cause the car to not start at all?
hoping to run daignostics shortly and see if the ecu throws any codes.
thanks guys
