s13drifter88 »
https://forums.nicoclub.com/s13drifter88-u163198.html
Thu Jan 13, 2011 9:19 am
what maf do u have. def make sure the maf is atleast 12" away from the turbo. I try to get as far from the turbo as I can, it just depends on how much space permits me to move it away. turbulence thru the maf tho when to close to the turbo with cause some seriously fubar'd signals. stock everything back out and then adjust your throttle voltage, set timing to stock, move the maf away and then you can begin to modify things one step at a time. it'll make life sooooooooo much easier chasing one problem at a time than a whole bucket of problems at once
