ca with sohc maf about to max out on 10psi"
dvd
Hey all, I have a ca18det with a aftermarket log manifold and a gt2510. My current setup is a blowthrough SOHC maf and I have a safc2. Ever since i had the safc i noticed that the maf is always close to 90% when i'm flooring it. FOr example: while driving back from work i floored my car to 100% throttle and according to the afc at 5555rpm the maf was at 91% and turbo was boosting around 9~11psi probalby 10. Is that posssible? Or is there something wrong with my maf wiring?
kapower06
No its possible that the SOHC mafs is maxing out as it only reads 210whp so im not sure what that turbo is capable of, but it may be close... 210(.91)=191.1 hp. 191.1 whp is pretty easy to reach. switch to a N60 maxima MAFS they are good to 325whp. With my hybrid turbo and stage 3 chip from Horsham Developments, at 17-19psi I hit 88% 325(.88)=286.
I just so happen to have an extra N60mafs if ya want it for cheap. lemme know.
dvd
do you have the pigtail too?
sideways danny
Car: s13, CA18DET
how similar is the 240 sohc MAF to a genuine CA18DET maf? I've heard people say the CA MAF maxes at 190rwhp but I know of many many poele running it reliably way past that. I wouldn't trust the SAFC scale for the MAF limit personally
float_6969
Yea, the stock MAFS (or a SOHC) isn't hard to max out at all. If I was still running a MAFS, I be maxing it out on the stock CA T25 at 15psi. You've got a much more efficient turbo so I'm not suprised to see you're that close to maxing it out.
Pick up kapower's N60. That will give you plenty of headroom.
float_6969
It's a very slightly larger diameter. Close enough to the CA MAFS that most people can use it w/the stock ECU and not really have any issues.
mbmbmb23
I believe the gt2510 is good for 250hp on SR's (it's basically a ball bearing version of the stock S13SR turbo).
-m
sideways danny
Car: s13, CA18DET
float_6969 wrote:It's a very slightly larger diameter. Close enough to the CA MAFS that most people can use it w/the stock ECU and not really have any issues.
well I'm still using a stock CA MAF and my power grap is in the dyno sheet sticky
float_6969
Do you think the blow through setup is causing an erroneous reading? I can completely believe that the MAFS % on the SAFC is wrong.
And now that I think about it, here is a little math for everyone...
TT Z32 MAFS was used on a motor that produced 300HP in stock form. That MAFS is capable of supporting 500HP IIRC.
That means that it is oversized by a factor of 2/3's. (AKA, multiply 300 by 1.6)
If this MAFS oversizing holds true, then the CA/SOHC KA MAFS is good to right at 300HP.
I still think it's a pretty big restriction to the intake tract of the turbo, and it certainly can't hurt to use the Maxima or Z MAFS.
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
what does the maxima N60 maf fall under when looking at the SAFC2? I myself have a maxima maf and was trying to find the sensor number it usues. The booklet doesnt mention maximas, just Z32's and sum other VG engine powered cars, but nothing maxima.
rico05
Car: 1992 RMS13 w/ CA18DET
Odd. I spike to almost 1bar and I have never had an issue on my SOHC MAF. I run 12psi daily on a T25G, and had never an issue.
davidricardo86
Car: 1992 Nissan 240SX SE
Hey kapower06, how much for a Nissan Maxima N60 MAFS w/ pigtail shipped to 60804-4114? Thanks.
float_6969
I think it's the same as an RB20 MAFS. Maybe that'll help.
rico05
Anyone know which MAF to select in LiveEdit for the N60 MAF? Is it close enough to the RB20 MAF to select it?
float_6969
From what I've heard, it's the exact same thing as an RB20 MAFS.
dvd
nah even when it wasnt blow through setup it still had the same percentage.
float_6969
As danny said, IDK if the SAFC % can be trusted. What I suspect that is it is basically a percentage of what is supposed to be the maximum signal from the MAFS, which is 5V. What I think is that the MAFS is actually capable of more than a 5V signal and that is why the percentage is perhaps skewed.
dvd
maybe because I have my settings for the maf set to the ca18det's in's and out? probably no different because the sohc reads the same right?
float_6969
No, I think it's off by 1 number from the CA MAFS. I don't know which as I've never really messed with a SAFC.
dvd
i guess my next question is anyone with a sohc maf can tell me did they use the ca maf settings or used a ka sohc one? I'm thinkign it should be run on 5?
TurboFortysx
Car: 240sx Coupe 2JZGTE
I have tried three mafs,the CA, SR, and KA. The best one I got to work was the CA maf which maxed out at 330 rwhp at 14 lbs.
Liquid_Neon
any one know if the DE and DET mafs are the same? ill check my de part number when i get a chance.
