CA wiring and voltage help
mod_mastaz
Hey guys I need a little tech info on the CA wiring. I have read the links and have found out which wires does what. Now comes the hard part.
I need to find out how many volts these wires are supposed to get:transmission neutral switch - still not sure =(ecu relay - grounds the relayecu power - 12V switchedecu backup power - 12V constantmain ignition power - 12V switchedignition start (forgot it) - signal from ignition switch when cranking
So with these, in addition to getting the fuel pump on, the motor should run? No, I'm not trying to get this to run in my garage, its for an S12 swap.
Modified by mod_mastaz at 6:06 PM 3/12/2008
Modified by mod_mastaz at 11:04 AM 3/16/2008
mod_mastaz
bump! I still need help. =(
mod_mastaz
Bump, I need to find a way to bypass the neutral safety switch because the S12 FS5W71B turbo trans does not have one. The fsm says if the sensor gives continuity in neutral, so do I ground it to complete the circuit or does it need voltage?
