Red93coupe wrote:So i was down at the shop again all day there is definently spark but no fuel the pump works i can hear it when i turn the key on, could it be the resistor and another thing do i need to have the intercooler piping hooked up in order for it to run because i know the butteryfly valves run off of vacuum and so does the fuel pressure regulator please help I don't want to put the raunchy ka back in it!!!
Can you smell gas in the exhaust? Check your fuel lines to make sure you have them hooked up right, the one with the filter should go to the rail, and the one w/o the filter should go to the FPR.
