Veen wrote:
top hose there, you have it pointing wrong way, rotate it first towards the back (axis of rotation being the air regulator its attatched to below) and then you should find you're able to get it on a same sized fitting there that goes into the intake mani. This is for the cold start stuff.
Bottom one goes to the coldpipe, this is the air inlet for the cold start and idle stuff (see the T there? going 'up' in the picture goes to the cold start regulator and going 'left' goes under the intake mani and around to the other side to the idle BS)Quote »[/quote]Yes, the left section you are asking about is the brake booster hose. You can get one from a KA (SOHC anyhow) and cut it to fit w/o problems, or get some generic hose, same.
Your PCV is correctly hooked to the hose running left-right to the valvecover.
The plug you question is for the AC, fast idle control. If you have no AC you can forget about it, but don't take it off unless you can find something to plug it with. Keep in mind it has little parts inside if you do take it off. If its not broken, you might consider taking it off anyways and storing it safely as they almost always are broken, and someone can probably use a good one.
Quote »[/quote]the spring is part of the stock air ducting, looks like the front end of it is cut off, its there to keep it from collapsing under the intense vacuum in front of a boosting turbo. You could trim it down I suppose and try to make that work, possibly couple it to a short straight pipe before going to the MAF.. either that or get another new peice or get a hard peice made up.
Can't tell on that plug, what colors are the wires and what shape is it (i.e. 2x2, 1x4, etc) and in which positions are the wires?
Quote »[/quote]Yeah, you know, in Japan everything is backwards on the inside of the car :P so yes those are heater hoses you just need to ditch the whole back section there and run straight back from the under-intake-manifold pipe and the block exit on the (US) passenger side, straight into the car. Stock KA hoses (at least SOHC ones) will work with some trimming to fit, no problem.
You might have a few extra plugs.. stock boost control crap, the variable intake control crap if you didn't hook it up, if it was an automatic harness the auto dropping resistor and FPR rising solenoid..
