240Clarke »
https://forums.nicoclub.com/240clarke-u198631.html
Mon Apr 30, 2012 7:56 am
Fellas,
I am still new to the CA, have always been a KA guy before venturing in this direction a few months ago. Ive exhausted the search button, so Im resorting to new threads for help.
Okay, my setup is stock internal CA, metal head gasket, ARP studs, Nismo FPR, SR T25, HKS 12psi actuator. I have been running stock MAF and stock injectors until the other day, hitting fuel cut at 4.8k-5.2k religiously. A/F's have been abnormally rich, WOT at ~10.2 and idle at around ~10.9. (with A/C and headlights on, idle A/F is ~ 12.9-13.2...) I am "tuning" with an SAFC1, though no matter if I pull 50% fuel, the A/F's do not change more than .2. Boost leak test checks out good. Base fuel pressure set at 36psi idling. I thought I might have a leaking injector, making me run rich, so I just upgraded to DSM 450cc's and an N60 MAF (to possibly prevent the boost cut if it was caused by the stock MAF reaching its max 5V).
With the N60 installed, followed to a tee from a write up on Nico, and the 450's installed, the car will not run correctly. The SAFC recognizes 0 air flow. I am not positive of the SAFC settings for the N60, because there is about 4 different answers to the question when you search. No one seems to know the correct answer. Ive tried 2 in 7 out, 4 in 7 out, and 6 in 7 out, and everything in between. It seems to idle best at 2 in, 6 out. Which I know is incorrect.
So here is my question: does anyone know the CORRECT setting the SAFC should be at for the N60 MAF?
Second, the write up I followed did not have the thick white wire from the CA harness connected (12V constant?), can anyone give me a proper explanation of the wiring. I will post pictures of which wires I have connected to which later today.
(How I have it wired)
Solid white -> not used
Solid black -> to both grounds (pins c+d)
black/white -> white/black
black/green -> solid white
Third, does anyone on this forum socket and tune ECU's for common set ups? If so, PM me and well get something set up. I tried Emance with my SOHC KA-T, and the car barely ran, was inoperable below 3krpm, jerked and bucked like crazy, etc. So Id prefer not to travel that route again if possible. And US based companies that are familiar with the CA ECU? It appears the Enthalpy does not support the CA. I prefer not to go stand alone at this point in time, doesnt seem necessary with my set up.
If any additional information is needed, please let me know. As always, I appreciate the help.
Tyler
