knightrider »
https://forums.nicoclub.com/knightrider-u3208.html
Tue Aug 01, 2006 7:06 pm
also, i did this because my boss at work wanted to try it out. the ecu cost me nuthing, but in my quest to find one, i found they go for 100-200$ normally. my boss also liked the idea of having the consult to help with tuning.
the zenki S14 ecu also has the letters WC on it, i dont know if there are other models but that one that i found that had the wide blue plug. the difference between the wide blue and the narrow blue is; the narrow blue plug has 48 small pins + the larger 101-116 pins. the wide blue plug has 60 small pins and the same larger 101-116 pins. the CA is a wide blue connector.
