ca timing problem help!!!
slidingA240sx
Car: 1990 s13 ca18det swap
hay guys wondering if anyone has had this problem b4 i just swapped in my ca i got it for next to nothing!!!!!! an im having a problem when i set the timing to 15 deg the car would bog and run pig rich..so i adjusted the cas to like 45 deg or some **** an it runns better but but not much power. help me please thanks
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
first post here and can't even say hi...tsk tsk
slidingA240sx
l
sjbsuperman1425 wrote:first post here and can't even say hi...tsk tsk
ol sorry whats up guys im new to the site and need some help with my ca ....happy lol
zero_gripS13
Car: soon to be 95 s14 hopefully
remove your cas and check the pin in the cam shaft see if its broken....
if not check cam timing might be off.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
zero_gripS13 wrote:remove your cas and check the pin in the cam shaft see if its broken....
