ca technical q's
badbennyb
what is the rod length of a stock ca18 rod?what is the rod length of a stock ca20 rod?what is the center spacing on a ca18 and ca 20?is the snout length the same on ca18 and ca20 cranks?is there ANY differances in the bottom end of SOHC and DOHC motors?
any info on ca18det's with ca20e or ca20s cranks and rods?
thanks in advance.. bennyb
if you wanna tell me to search... you try it first..
float_6969
Rod length of a stock CA18 rod = 132.95 - 133.05mmDon't know. Center spacing of what? I'm pretty sure they're the same. SOHC and USDM CA18's lack piston oil squirters and crank girdles. It's been tried, but I think there was either clearance issues, or strength issues.
badbennyb
[0000] / \center spacing is the distance from the center of one cylinder to thecenter of the next.. basically how much you can overbore and still be safe...
thanks for the info... bennyb
