DammitBobby »
https://forums.nicoclub.com/dammitbobby-u6954.html
Mon Oct 30, 2006 9:21 am
Ports or probably better term signal. A lot of turbos have a barb fitting on the compressor side that you would attach a wastegate to. I use the brake booster line for the boost gauge and bov.
"yes i can dissconect the line between the turbo and wastegate were my boost controller is and still no more boost"
I am not sure if I understand you either. Did you disconnect the wastegate signal or did you disconnect the boost controller. If you disconnected the signal from the wastegate then it should boost to whatever the turbo can produce. If this is the case then you need to look for a boost leak, missing fiery ring, bad turbo etc.
