ca t25 vs sr t25
euroboy
have heard that there are differences i can't anything on this new site so if someone can shed some light?thanks Bess
float_6969
CA = Crappy Azz Hair DryerSR = Less Crappy Azz Hair Dryer
It's a moderate upgrade, nothing crazy. The exhaust and compressor blade are slightly larger. You MIGHT notice a little more lag, but it won't heat the air as much and you'll boost a little safer.
rico05
Car: 1992 RMS13 w/ CA18DET
The "T25" found on the CA has an A/R of .40 and is in all actuality a "T22". The A/R of the S13 Red/Blacktop SR was .80 Don't boost the stock T22 over 12psi or the T25G over 15psi unless you want them grenaded fast.
