Ca Swap
Broken Wings
Car: 1991 Nissan 240sx SE
I was wondering if i could use a stock 240sx manual driveshaft with a ca swap. Or do i have to get a ca driveshaft. And does abs matter with he drive shafts?
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Ooooo Ooooo better do some research there buddy before you get flamed to death lmao:D But yes just use the stock driveshaft
Broken Wings
Thanks. i tried searching the forum but nothin turned up. But i just found that the abs driveshaft is slightly longer. Thanks for your help man.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Broken Wings wrote:Thanks. i tried searching the forum but nothin turned up. But i just found that the abs driveshaft is slightly longer. Thanks for your help man.
WRONG the abs driveshaft is slightly SHORTER than the non-abs...i know i have one, and its about a 1/4" shorter but works fine.
Broken Wings
Thanks. Apparently my friend is anidiot. I appreciate the help guys
