xyster »
https://forums.nicoclub.com/xyster-u1869.html
Tue Mar 30, 2004 4:50 am
With $3k you might be able to get the motor swapped in at a shop, but everything will be completely stock. If you do it yourself, and shop for bargains, you can prolly get a walbro fuel pump, manual boost controller, gauges, slightly better clutch, maybe some new gaskets/seals/belts, and good fluids (redline). Either way, you're looking at a pretty much stock setup.
Where are you located?
