float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Aug 16, 2006 7:18 pm
It drops in no problem. What you were hearing about the motor mounts was that they are slightly different than the KA/SR mounts. You can get the proper ones from the UK. The KA/SR mounts will work, but as was stated previously, they don't tilt the motor as much and it sits higher, making STB's a bit of a pain to clear. Everything else is pretty much just like the SR. One thing to remember is that the CA doesn't have a BOV/Recirc valve like the SR and the CA sidemount is smaller. Also, CA's tend to be older and need a little more freshening up than an SR does.
Not to turn you away from the CA, but if you're looking to be different, have you considered an RB20? I just saw one on the dyno today, in basically stock form, put down a healthy 230hp. As long as you're not looking to do any grip/autoX with the car, it's a decent little motor. I was impressed.
