busteds13 »
https://forums.nicoclub.com/busteds13-u56647.html
Wed Mar 25, 2009 3:58 pm
Rico,
I have a strange story for you, i blew up two KA's which were old, they threw rods through the block AFTER i had done all of MY not the previous owner oil changes with full synthetic (royal purple). After buying the CA i did reaserch on oil, i didnt do any rebuild but i change my oil with semi synthetic, and will never use full synthetics again. and it runs happy.
anyways, i was wondering if you figured out the culprit for the unfourtinate kaboom, and if not i urge you to consider looking carefully at your oil choice, I read that older engines that were not started on synthetic and used dino oil all their life, tend to buid up oil sludge, that slowly adjusts your ring gaps and bearing to crank gaps to work with the engine and changes (over tyme), and when you switch to full synthetic, it slowly clears all the guck, and then your clearences are off, stuff starts walking around and then you get the dreaded boom. If you did full rebuild its prolly not gunna be that much of an issue, otherwise, i believe royal purple could be an engine killer.
Long winded, and just a thought, i hope the next one is nicer to you.
