CA stroker Kit
float_6969
Ok, so maybe I'm just the last one on the bandwagon, but I didn't realize that Tomei make a stroker kit for the CA. It takes it up to 1950cc. Now THAT would be awesome. I'll bet that a CA with that displacement would kick the crap outta some SR's.... JK, nothing wrong with the SR, if you like Rocker Arms...
CA19DET
honestly, i odnt think it is worth it, with the money you could just buy a hell allot of parts and modify the hell out the CA18..
or just get the over sized pistons and go to CA19 like me and others..
i also see that courtesy nissan sells CA20 cranks so there is a cheper route to this... just need the custom rods and pistons (from TOMEI??) lol...
float_6969
Well I was thinking stroker kit and bored out. Maybe get 2.1L. Now wouldn't that be crazy. I'd think with a stroker kit, it wouldn't rev out like it normally does though. I don't think I'd want to give that up. I mean, if I was going to build a drag car, I'd go turbo KA w/o a doubt. It's a friggin torque monster. I don't really think I'd ever even be intrested in it, I just thought it was cool that there was some love out there for the CA, you just have to look hard to find it.
Trigger
i bet with the stroker kit and boring it out you would be able to spool the t3/t4 very fast......a very interesting though...i was thinking about that last night. I am going to look into the stoker kit and do some research about it
Tim
CA19DET
i think the CA can spool a T3/T04E pretty fast, and remember that a T3/T4 at 8 spi is flowing allot more that a T25 at 12... so even though the T3/T4 may not be making full boost, it may still be making more power :) and wehn full boost does kick in, that little T25 better be carefull not to get sucked in...
now if i could do it again, i think i would have gone with the GT2540R turbo...
Myetball
I'm still planning on getting my CA18DE stroked. I'm looking at around $1,300 for parts and machine work for the kit. This is a little rundown of what the kit includes:
- Stroked Crank 0.250" Stroke Increase: Journals ground and rebuilt with Nickle-Chrome alloy, Glasspeened, Balanced- Custom Stoker Pistons: Relocated wrist pin hole, Knurled, Balanced, Ceramic Top Coat Heat Shield- Deves Rings
I'm not sure what the exact displacement will be as it depends on how much overbore I want. When the kit is made, you can order any compression piston you want, no additional charge. I'm probably gonna go for 11:1.
themadscientist
the kit is not a requirement. most of the fastest CAs are slightly bored up with no stroke changes.
Xero
^^ding ding...
one mil. over gives you a 1.9L
Myetball
I was planning on going .040 over anyway so with the .25" stroke it should come in just about 2.0 liters.
float_6969
You loose your rev speed when you do that though. I guess it depends what you are wanting to do with the car. If you drag/street race then I think stroking it would rock, but I think it would hurt the powerbband and make it hard to autocross/road race. I've never seen it done and I've never seen a dyno of a CA that's had it done, so I could be totally off base here too.
Myetball
Well, I'm hoping to get a nice boost in power. I've already installed a throttle body from a KA24...it's huge compared to the CA18DE throttle body. Should come in handy when the displacement increases. I'm going to run it stock, it's a JDM Bluebird engine btw, for a while until I get the funds to modify it. Of course cams and injectors will be upgraded as well, among other things, and a piggy back sds.
float_6969
Just so ya know, SDS isn't piggy back, it's standalone. I'm going to put my KA-E Throttle body on my CA too, but it's because I want to keep my cruise control. :D
NeedCAforS13
Car: CA swapped S13 coupe
will the E work? I was under the impression that only the DE Throttle body worked?
Sean
float_6969
I don't know, I'll find out in a couple of weeks I guess! Hehehe
Myetball
Here's a link that describes what I found out about the KA24E throttle body and what I had to do in order for it to work...pics too.
float_6969
Thanks! How much material did you have to remove to get the manifold to port out to the size of the KA24E Throttle body?
Myetball
Quite a bit, I'm guessing around 4mm all the way around. I believe the CA is 52mm while the KA is 60mm. Wasn't easy, especially without a die grinder but it turned out real nice and real smooth.
float_6969
What did you use? I've got a dremel and thats what I'm thinking...
Myetball
That should work well. I used my son's muscle and a large rasp file that was curved on one side. Finished it off with a polishing bit on a drill. I really need to invest in some more power tools.
float_6969
Dremel tools are awesome! Get one, for sure.
