xyster »
https://forums.nicoclub.com/xyster-u1869.html
Wed Mar 30, 2005 12:18 pm
I've had a CA in for a while, and it always seemed to rev pretty slowly, but I haven't been able to touch it in 8+ months (iraq deployment). I've spent the past week or so trying to get it to run better. Alright, here goes:
-Stock swap, plus Greddy VSPL FMIC, HT hot pipe, Blitz SS Bov, Walbro 255, Infiniti J30 VLSD (in case it's a gearing issue), Spec Stage 1 clutch, Autometer mechanical Water temp/boost/oil pressure, Apexi SAFC II, HKS turbo timer, pdm racing catch can - plumbed per thread on SXOC.
-Stock boost, which with the fmic peaks to about 10 on the gauge as read from the vac port in the intake plenum right behind the TB
-It idles smooth, 800-870ish, idle tuned per FSM
-Timing 15 BTDC, set with cut plug wire on first coil method, done twice
-Water temp as measured at upper rad hose is about 175-200, depending on ambient and driving style
-ECU is throwing only code 55 in Mode 3, and seems to be blinking a proper mixture in modes 1 and 2, which leads me to believe the lambda is good (correct me if I'm wrong)
-Today, I got out the FSM: reset the idle, checked the resistance on TPS, idle switch, various idle-related valves, injectors, ecu coolant temp sensor (newly replaced)
-Checked all the clamps and connectors on the fmic piping...can't feel/see/hear any leaks...I intend to pump it up with my compressor as soon as I can find the right size cap for the turbo inlet. Boost seems stable while driving.
-I got no continuity across any pins on the TPS, with the throttle open or closed. I assume this means it's bad. Could this be causing the problem?Edit: Lemme clarify here: By TPS, I mean the actual TPS part of the throttle body sensor...the one that has a small "pigtail" cable with a brownish plug on the end...not the actual square black box with the plug molded in. The FSM leads me to believe the molded plug is for the "idle switch" and the pigtail is for the throttle position sensor.
-Little to no oil in FMIC piping, turbo spins freely with little to no play, axial or radial.
-I replaced all the gaskets between the head and the downpipe less than 1000 miles ago, and put lockwashers on all the bolts. All are still tight.
-Edit: New plugs, all of which still look new. All the coils are good (checked continuity, and did the "pull a coil and see if the idle changes" thing).
-Edit Again: Alternator charges fine, battery is relatively new, redid all the grounds today, turbo timer reads 14+ volts.
i'm at a loss here...it seems like I've checked everything. Does the CA just really rev this slow? It feels like my vg33e Frontier revs faster, even in high rpm. I added the blitz bov today, and it seems slightly more responsive...but still. Maybe I'll make/post a vid of it running in a day or so.
Modified by xyster at 5:32 PM 3/30/2005
