CA S13 swap...
downhillspecialist
Car: cars
skoolymarms ca just came in as some of you guys know...i know im kinda being lazy but...just a couple replies here and there would help some new CA guys to the scene...
the ka is comming out tonite ...
any prelims we should know about before we start to pull the CA ???anything to keep....i know the heater hoses dont line up and so forth...i've done an sr swap before...any simularities?
little stuff here and there would be very much appreciated from skoolymarm(jovan) and myself...(jimmy)
thanks guys...
euroboy
well it's more or less a direct swap.If you don't want to go into costum making stuff then s13 with ca18det is the way to go. Heater core hoses is no propblem if you need a heating core then you just change them, the brake booster on the other sidewiring go to http://www.srswap.com and go to faq install and there you have the wiring for a red top early year sr is the same as the ca18det.The whole shouldn't take more than 2 days MAXi have the s12 and for us it was a bit more work to fiddle around with but very doable as well
Bizz
any special tips for us S12 swappers?
