float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Nov 26, 2004 8:27 am
Glad to see you back man! I actually think this sounds like the IACV or whatever it is. It's that little round, fat, gold cylnder attached to the side of your intake mani. It's the green thing in Sean's sig actually! But anyway, if you're sure that you don't have ANY vac leaks anywhere (quadruple check, and then have SOMEONELSE quadruple check) that would be the next step. But make for damn sure it's not a vac/boost leak before you start messing with it.
