If I were any of you, I wouldn't be trying to peg the max limiter on your ecu, tach readings, or whatever. Stock engine, no cams, no head work, stock ecu, be sure and shift no later than 7200rpm. You've been warned !haydennd wrote: I did a search on this but no help. I'm thinking about getting a S13 with a CA. I did read most of the stickies but not all of it. I was just wondering what is the stock red line on this motor?
