jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Wed Nov 12, 2008 9:29 am
Ok I don't know why but I've done my headgasket twice now and it's leaking still. I have been very meticulous and inspecting everything, trying to be as careful as possible, yet I still do not have the results I want. It is very upsetting and demoralizing. This last time I...
- had the head resurfaced- *tried* to clean the block up with a perfectly flat steel block and 400 grit sandpaper : it came out smooth and flat to within .04mm (<.1mm spec)- new headgasket (no copper spray)- arp headstuds
Both times I have found leaks on the driver side of the engine, very back, between block and head. Right above the CA18 imprint on the block. This time not only is oil coming out, but coolant as well. I have not been able re-torque the headstuds on this last time around since I stripped a valve cover screw last night, but I will when I get home from work today. However I do not think it's likely that this will fix my issue.
So my plan now is to get it rebuilt by some shop here in Atlanta. I think the entire engine could use a fresh start anyhow other than an in car headgasket job. I'd like to list the components I want to get replaced and see if anyone can add to this. This is not a high horsepower rebuild but I would like a solid base to start modifying. The engine will not go over 280whp in the next few years.-Oil pump -Crank timing cog and woodruff key-Front and rear main seal-Main bearing-Rod bearings-Piston rings-Headgasket-Timing belt-I can re-use the arp's ya?
One of the things I had noticed during the last two installs, even with the headstuds in place and the dowl pins on the head, the headgasket is still able to slide around on the block. What I mean is, there are a few different positions it could lay in during installation. If I tried to center the fire rings around the cylinders, the oil passages on the HG were not quite on. If I tried to center the oil passages, the fire rings and coolant holes would not be quite on. Any expert advice on this point?
Thank you all and hopefully I can have a strong CA18DET base to start messing with, something I've been working hard for these last 4 months.
Jon
