At what rpm does this rattle takes place?theShadow wrote:So its definitely lifter tap? And I don't neccessarily have to chang them, I could just take them out and clean them?
Its usaully the lower rpms, or if I'm really light on the gas going through parking lots, resedential areas, stuff like that.boost_boy wrote:At what rpm does this rattle takes place?
Dee
You have rod knock my friend. You're under load and the thing is rattling? That tells me you have a spun bearing and not a bad lifter. This engine rarely develops bad hydraulic lifters and if it does, you usually end up with a motor that runs funny.theShadow wrote:
That would be it. Know of anyone else who has had this problem? What can be done to correct this problem?fluent wrote:While parked in Neutral, rev it to ~3000rpm slowly and then slowly let go of the accelerator while listening for any rattling sounds. Big end bearings knock is extremely hearable around the 2500-3000rpm range.
