bias »
https://forums.nicoclub.com/bias-u49508.html
Fri Dec 08, 2006 9:57 pm
I just did it. Easier than I thought. You have to get the engine/transmission, wire harness complete , ecu, intercooler/piping, stock harness, 91-94 gauge cluster and power steering lines, KA speed sensor, soldering iron/rosin solder, electrical tape, engine lift, jack, oil, antifreeze, wrenches, scissors,flat head screw driver, down pipe, exhaust(more than stock),and patience. You have to check your engine very well just in case you need to replace some stuff before you drop it in, clutch,gaskets,bolts,oil seals etc. It's not hard at all if you have help tp get the engine in the bay and transmission mounted.
