To anyone changing an automatic CA to 5 spd, USE A CA18DET transmission!!!! DO NOT USE A CA18ET. Its about 3-4 inches too short and you will have to cut the shifter hole in the chassis a lot bigger towards the radio and ac controls.
His shifter was also ghetto rigged by the shop and he had to have a custom driveshaft made.
Anyway, since we were swapping the trannys we were also going to install a SPEC stage 2 clutch.
I put the disc on with the alignment tool and get ready to put on the pressure plate when I come to find out the flywheel is too small for the pressure plate to bolt on too. Smaller by 3/4" of where the bolts need to be.
I ask my friend what was used for the 5 spd swap parts. He said 88 Pulsar flywheel and clutch.
Ray (Drumma022) checked the SPEC part #'s and its not an SR20 clutch but its definately a CA clutch #.
So I get to thinking and my question is, Is the CA18DE flywheel from the US Pulsars smaller than the DET flywheel?
The DET clutch disc is also bigger in diameter by 1/4"
This is where you come in Sean
I need to compare Davids SPEC 2 clutch kit and his old Pulsar clutch to a DET flywheel. Is the DET flywheel you have still off the motor?
