Doogz »
https://forums.nicoclub.com/doogz-u5748.html
Mon May 19, 2003 5:20 pm
I tried to fire up the CA today and here is what happened. It cranks but i couldn't hear the walbro pump (which i figured i should be able to) So i took off the fuel lines and im getting no gas. I took off the harness (6 pin harness with only 5 wires used) in the trunk going to the fuel pump and tested the wires and this is what i got:Top left (all black wire)= i get no reading at allBottom left= pin that is not in useMiddle top (black wire w/ red stripe)=12VMiddle bottom (green wire w/ blue stripe)=7.6VTop right (black w/ yellow stripe)=no reading at allBottom right (all black)=ground
So i have 5 wires to the fuel pump and only 3 in use...also, im not sure if this makes any difference or not but my gas gauge is not reading anymore. Any help with the fuel problem???
Also...after all of this...i was cleaing up the tools and i notice oil dripping from my downpipe (was all i had hooked up at the time) so it looks like i'll need a replacement turbo. I just need something cheap that'll drop right in and last for a little while. Finally, can the turbo be replaced w/o engine removal?
