I did mine the same way as knight rider. You just use a dohc reservoir, then unclip the far end of the power steering line beneath. There's a rubber section in the line that allows it to bend, and you just bring it up and hook it to the pump. No metal lines are kinked or even had to be bent, and I used to new rubber lines from and to the reservoir. I can understand how this is a little ghetto, but don't see how it would be a safety issue. I have'nt had any problems so far and it's been like this for a year.MegasquirtCA wrote:if you wanna do it the ghetto way and risk the chance of failing than sure you can use your SOHC lines. the DOHC lines bolt up though no mods required.
