lovemy89240 »
https://forums.nicoclub.com/lovemy89240-u149336.html
Thu Jan 05, 2012 12:11 am
As the title states i have 2 questions
1. What is the normal running temp for these engines? Right now I'm running what i asume to be a stock thermostat with an afco dual core full aluminum radiator and mishimoto 12' elec fan, and during mornings and cold outside temps it'll stay around 125F,
during the day, normal driving and even spirited driving my temp stays at 145-150F, is this normal? (incase it helps I live in the san Francisco area so the temps out side usually don't go over 75 haha)
Also if I sit in traffic or let it just idle after a drive the temp will rise to 180-210F
If you guys could help figure out why or give me advice on how to fix this I'd appriciate it.
And my second question is, I have my ecu mounted in my glove box (Datsun 510) with the diagnostic lights facing me, now when I'm accelerating or just maintaning speed I see the green light flashing and the farther I push the pedal down the faster the LED will flash,
also when I hit boost (positive pressure) the led will stay solid green sometimes, but the led will also turn off when I hit boost othertimes is this normal?
Also when I come to a stop I'll notice my idle will drop and the green LED will come on. Is this normal also?
Any helps appriciated, Thank!
lovemy89240 on Thu Jan 05, 2012 8:01 am, edited 3 times in total.
