Ca no crank.
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
Hey, gotta problem as usual.
Go to start the car, turn key into ignition, fuel pump whines its little heart out, everthing on the dash comes up, pentype turbo timer says 12.8v.. fully sick.
When go to hit on, starter won't crank at all. nothing.
But if i put the key onto ignition, put 12 volts onto the starter motor solenoid, car cranks fine, everytime. that so, atm, i have a momentary switch where 1 side is hooked upto ignition, and the other side is hooked up to the solenoid, so i can get around.. kinda like a honda s2000 :p
I have checked all fuses, fuseable links, and the relays under the bonnet.. but wheres the other relay under the dash ??? i can't find it anywhere.. and it's pissing me off !!
Anyone can help ?
Pete
