ca motor with sr turbo
crazygrk3
i got a ca motor with the turbo of a sr motor and its i getting a to much lag and i run pretty rich anybody got any ideas on wat i can do to getting running normal
c-rad
Car: 1991 Nissan 240SX w/CA18DET
crazygrk3 wrote:i got a ca motor with the turbo of a sr motor and its i getting a to much lag and i run pretty rich anybody got any ideas on wat i can do to getting running normal
Too much lag? Mine was hitting full boost around 3k before it grenaded.
themadscientist
I put an S14 turbo on the ex's Ca and it spooled up quicker than the CA one did. Something is not right. Did the turbo you used spin freely and have no visible damage to the wheels?
float_6969
You say SR turbo. Is it a T25 or a T28?
1via
I have a t28 on mine. I used to lag extremely. I looked over the motor and found that the hose from the intake manifold was cracked. Replaced it and now its all good.
crazygrk3
im not sure if its a t25 or t28 how would i find out
rico05
Car: 1992 RMS13 w/ CA18DET
Start with the A/Rs of the turbine housing and compressor. My SR (.80a/r T25G) spools full before 3k RPM.
crazygrk3
i look at my turbo and its a t25
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
rico05 wrote:Start with the A/Rs of the turbine housing and compressor. My SR (.80a/r T25G) spools full before 3k RPM.
Yep sames here
crazygrk3
i happy for you but how does that help my problem
c-rad
crazygrk3 wrote:i happy for you but how does that help my problem
What do you want us to do? I don't have a "fix his car" button on my keyboard. And yes, that does help your problem by reenforcing the fact that your setup is messed up. What could it be? 10,000 different things. Start with the turbo itself. Are the turbine/compressor blades chewed up or broken? Is your manifold/turbine housing cracked? Do you have a big exhaust leak somewhere between the head and turbine housing? Do you have any boost leaks in your intercooler piping or intake manifold? Is the timing setup right on the motor?
crazygrk3
well thanx for the help
float_6969
As C-rad said, it could be a lot of things. First things first, check for codes on the ecu. If you don't know how, then go up to the stickies (you should have read them already ) and download the FSM. Everything you need to know is in there.
Comeback and let us know if the ECU is throwing any codes or not and we'll go from there.
crazygrk3
sounds like a plan
